how do you get to the damn fuel pump - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 5th, 03, 03:16 PM Thread Starter
dont wanna remove the rear and exhaust to do this fuel pump...cut a hole in the floor thought it would be easier only to find HARD gas lines...which connect to a disc..when i try to pull it out, it only comes out halfway..not enough to change the pump.. and you cannot remove the lines..any ideas? e-mail me [email protected] thank you!!!
Jame
purplecamarogrrl is offline
post #2 of 3 (permalink) Old Jul 5th, 03, 04:36 PM
Guess
HwyStarJoe's Avatar
Thumbs down
Ouch! Cut a hole in the trunk?
You're gonna have to drop the fuel tank to get the fuel sender out. Or keep cutting....
HwyStarJoe is offline
post #3 of 3 (permalink) Old Jul 5th, 03, 07:00 PM
I've seen it done on a 93-96 Camaro and they had to drop the rear end, the tank and from there they changed the pump. Not a real bad job considering. As a side note, welcome to board. Stick around and you will learn more than you could imagine [img]graemlins/waving.gif[/img]
1969 export
Judd is offline
