where is the fan relay located - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 14th, 01, 10:50 AM Thread Starter
where is the fan relay located on a 91 camaro RS 305 5.0 . weve pulled the fan out and disengaged the electrical connector?
gregs91 is offline
post #2 of 2 (permalink) Old Oct 14th, 01, 02:15 PM
Lightbulb
greetings gregs91, i don't know for sure about the '91rs, but on the '89 iroc it is located on the right hand fender between the battery and the overflow tank. you also should have a heavy duty coolant temp fan switch located on the right hand side of the engine block just above and aft of the starter solenoid near the last spark plug. it has a single wire connector on it.
trickster is offline
