sparkplug acessibility - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 4th, 03, 10:35 AM Thread Starter
If you own a 69 bigblock car with air,can you please give me some advice on how to get to the #8 plug. This has been a wrench throwing experience, any help would be greatly appreciated.Im doing good to just touch the plug much less get the thing in and out. And did I mention that I got this in initially with the front cap off!
David P is offline
post #2 of 4 (permalink) Old Mar 4th, 03, 10:54 AM
Depending on your exhaust(headers vs. manifolds), you can do it from underneath or you can place the spark plug socket on the plug and then use a box end wrench to turn the socket. That method allows you fit in a little tighter space. SLP back yard engineered a nifty little device for the LT1's in the 4th Generation F-Bodies. They took a spark plug socket, shortened it and drilled out the socket hole so you could really fit into tight spaces I bought one from them when I was rebuilding the 93Z. It works great. If you have the machine tools or know someone at a machine shop, you could probably make one yourself. Good luck with that plug.
69X11SS is offline
post #3 of 4 (permalink) Old Mar 4th, 03, 05:31 PM
Ramps are cheap ($20's) and easy to drive up on.
Snatchin'gears is offline
post #4 of 4 (permalink) Old Mar 4th, 03, 10:10 PM
Have a 68 BB w/air. I took about a 1/2 inch by 1.5 inch bolt, and ground down the end of the bolt(make it square) to fit into a 3/8 drive spark plug socket. Put the socket on the plug, then put the special bolt into the socket, then put an open end wrench onto the special bolt, remove the plug. I could not reach the spark plug socket with out the bolt, exhaust manifold in the way, socket too short. Do this all from under the car. Bolt extends the reach into the spark plug area. The real treat is removing and reinstalling the spark plug boot. Good luck.
f105thud is offline
