Clutch/PP are out. Are they toast? - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 7th, 01, 05:26 PM Thread Starter
real fast. the reason that I took my clutch out was that it wasn't disengaging all the way and it wasn't the hydraulic part of it. the rivits closer to the surface are not even a 1/16 of an inch from being level with the top of the clutch discs. so i am pretty sure i need a new one. now the pressure plate, the "fingers" look fine. but the PP is all discolored like it was over heated and it looked like there was a few small spots that might be worn more than the rest. i have never looked at a PP before so i don't know if it is supposed to be discolored like that. it looks like brake rotors that i have seen that were warped and over heated. does it sound like any of this could be causing my problem? do i need a new pressure plate?
thanks for all the help
Tom Ziokowski is offline
post #2 of 2 (permalink) Old Oct 8th, 01, 04:26 PM
David Pozzi
davidpozzi's Avatar
Take a look at a new disk, there is very little difference from rivet head to clutch face on them too.
Look for a clutch rebuilder in your area and take the parts to them for an inspection.
They should be able to advise you.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
