clanking noise - Team Camaro Tech
post #1 of 6 (permalink) Old May 11th, 01, 07:06 PM Thread Starter
Unhappy
my engine makes a noise that sounds alot like when i blew a header gasket but I checked my header gaskets and they are fine the noise almost sounds like its coming from the middle of the engine and it gets faster as I rev the engine. it happened when I was racing a friend. I have a 355 chevy with 11.1 compression with a roller cam.
gg2rs is offline
post #2 of 6 (permalink) Old May 11th, 01, 09:25 PM
Dale
Sounds like you just used up a lifeline.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #3 of 6 (permalink) Old May 12th, 01, 10:27 AM
Talking
Is that your, final answer?
kz1000ltd is offline
post #4 of 6 (permalink) Old May 12th, 01, 06:43 PM
TOM
Cool
I say use another lifeline and poll the audience here !
That's my final answer.
TOMSTV is offline
post #5 of 6 (permalink) Old May 12th, 01, 06:47 PM
did u lose any power??? I had somthing similar happen and it was that i cracked a rocker arm and spit out a lifter. pull ur valve cover and check.
69 Camaro RS, 355ci mild cam, Preformer rpm intake, edelbrock 600 carb, 350 turbo w/ shift kit 2500 stall, 10 bolt 2.73 any more questions ask
69CamaroRacer is offline
post #6 of 6 (permalink) Old May 12th, 01, 08:26 PM Thread Starter
Yea it was the rocker arm I found one that was all loose. Thanks for the help
gg2rs is offline
