engine rpm falls flat - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 1st, 01, 07:48 AM Thread Starter
well here's the problem hope i can get some help. i have a chev 305 with AT trans when i drive and the trans shifts thru the gears all is fine till it goes into drive and then the engine just plain falls flat no power till i can get the speed up to about 40. ive set the timming and the vac advance is working and cant find any vac leaks only thing i havent checked it the mech advance. also when i shift thru thr gears manulaly and shift into drive at around 40 it seems fine please any sugestions????????
[This message has been edited by mark295 (edited 11-01-2001).]
mark295 is offline
post #2 of 3 (permalink) Old Nov 1st, 01, 08:19 AM
Welcome, were going to need more info such as what year car and motor and trans to figure this out.
Black 69 camaro
HOTROD69CAMARO is offline
post #3 of 3 (permalink) Old Nov 1st, 01, 08:28 AM Thread Starter
the motor is a 1986 and the trans is a turbo
and has a HEI dist. thanks for the help
mark295 is offline
