car won't start after reaching 150 degrees - Team Camaro Tech
post #1 of 8 (permalink) Old May 1st, 01, 03:35 PM Thread Starter
1988 camero: everytime my car reaches at least 150 degrees and I shut the car off if won't start again until the car has cooled to below 150 degrees. I have replaced the starter and solinoid and put a heat shield on as well, with no positive results. I have a 4 core radiator and have replaced the thermostat so the car normally runs about 190 degree. Any suggestions what to do next.
JohnWhet is offline
post #2 of 8 (permalink) Old May 1st, 01, 05:16 PM
I would try a remote solenoid like ford uses.
I use one on my camaro becouse of the headers. But it works great.
6-71BlownCamaro is offline
post #3 of 8 (permalink) Old May 1st, 01, 06:06 PM
Do you mean the starter won't turn over or the motor just won't start
oger is offline
post #4 of 8 (permalink) Old May 1st, 01, 06:09 PM
oger is offline
post #5 of 8 (permalink) Old May 1st, 01, 07:00 PM
Dale
Have someone crank it over,and check the volts,at the cables.Should be at least 10,while cranking.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #6 of 8 (permalink) Old May 1st, 01, 09:22 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by oger:
<HR></BLOCKQUOTE>nothing happens, but since it is a standard transmission I can push it and pop the clutch and the car will start.
JohnWhet is offline
post #7 of 8 (permalink) Old May 2nd, 01, 03:35 AM
The soleoid is sticking in it housing or the return spring is too heavy. Try changing the soleoid first. If it doesn't have headers you shouldn't need any of the trick fixes.
oger is offline
post #8 of 8 (permalink) Old May 2nd, 01, 06:30 PM Thread Starter
Thanks for the advise. I think I will try a ford solonoid before anything else.
[This message has been edited by JohnWhet (edited 05-02-2001).]
JohnWhet is offline
