1994 RS Performance - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 6th, 01, 03:20 PM Thread Starter
I have a 1994 RS and gave it the full tune up and it idle's a little rough, I changed plugs, fuel filter, air filter, wires etc. At idle it runs rough and performance is a little bad, Nothing major. I suspect maybe one of fuel injectors not functioning correctley. Sprayed intake with carb cleaner to no avail. Pulling injectors appears to be a great adventure!!!! Any suggestions before i do so!!! Car has 85,000 and has been well cared for.
mark
mark_dg is offline
post #2 of 7 (permalink) Old Feb 8th, 01, 07:50 AM
is it TPI? 3800 or 350, when you installed new wires you did them 1 at a time right??? if no better check the firing order again...
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING! http://nav.webring.yahoo.com/hub?ring=camaronet&list
[This message has been edited by Chris Edwards (edited 02-08-2001).]
[This message has been edited by Chris Edwards (edited 02-13-2001).]
Chris Edwards is offline
post #3 of 7 (permalink) Old Feb 8th, 01, 11:59 AM Thread Starter
It is a V6 which I believe is 305!
I change one at a time and the cars performance remained the same before and after service. The wires are about 1.5 years old with about 30,000 miles on them and after market parts!!
mark
mark_dg is offline
post #4 of 7 (permalink) Old Feb 8th, 01, 09:16 PM
Umm, a 305 isnt a V-6 (unless its from a mid 60's GMC truck).
Get a scan tool for your car and check the codes...scan tools are cheap, normally under $20.
travis is offline
post #5 of 7 (permalink) Old Feb 11th, 01, 05:55 AM Thread Starter
3.4 liter which is a 202!!
mark_dg is offline
post #6 of 7 (permalink) Old Feb 13th, 01, 03:56 AM
its only a 202??? WOW! that sux! hehehehe but I bet you get good Gas Milage, I think the old Chevy Straight 6 was a 250, that V6 is smaller than that. but outpreforms it.
post #7 of 7 (permalink) Old Feb 13th, 01, 06:00 AM Thread Starter
That is shamefull!! But that is what I read, I am having a hard time believing that is the size!! I got it up to 110 on the freeway. I guess that's a miricale! That is why they call it a 3,4 liter ift they told you the actual size no one would buy them!!
It still runs good with good mileage.
mark
mark_dg is offline
