Effective means for removing lower control arms. - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 15th, 02, 01:46 PM Thread Starter
They are all I have left to remove and the bolts and nuts won't budge.
Should I cut them off? Drill the bolt out?
Tony
Infamous is offline
post #2 of 3 (permalink) Old Oct 15th, 02, 02:32 PM
choptop's Avatar
Fortunately mine came right out, no fuss. You will need to persuade them to loosen up.
Have you tried copious amounts of penetrating oil yet? If not, try it! If that doesn't work I'd try using a propane torch to heat them up really good (be careful of fire!), then bash them with a BFH while hot to see if it losens the rust.
Then, if all else fails bring out the big guns- torch and/ or cutoff device.
Good Luck!
See my '68 RS/ZZ4
[This message has been edited by choptop (edited 10-15-2002).]
choptop is offline
post #3 of 3 (permalink) Old Oct 16th, 02, 07:11 AM
Guess
HwyStarJoe's Avatar
HwyStarJoe is offline
