KNOCK! weird one though.... - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 4th, 11, 10:25 AM Thread Starter
robert
rolling-robert's Avatar
my almost new 355ci started knocking.
in neutral, it doesnt knock at 500rpm, above it does.
When i put it in drive and hit the brakes, then open the throttle (while standing still) NO KNOCK!
so only in neutral and not when i put load on the engine, if you know what i mean.
i did pull the sparkplug cables 1 by 1, but it didnt make a change.
Therefore i dont think its a rod knock.
What do you think?
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 13 (permalink) Old Oct 4th, 11, 10:36 AM
Re: KNOCK! weird one though....
Check the bolts holding the flex plate to the torque converter.
Melrose RS is offline
post #3 of 13 (permalink) Old Oct 4th, 11, 02:29 PM
Steps
Weirld sound..get a stethoscope
Steptoe is offline
post #4 of 13 (permalink) Old Oct 4th, 11, 02:41 PM
Matt
Loose torque converter bolts.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #5 of 13 (permalink) Old Oct 4th, 11, 03:25 PM Thread Starter
robert
i rrrrréally hope so.
ill check tomorrow.
Z28 1984
post #6 of 13 (permalink) Old Oct 4th, 11, 06:39 PM
Paul
Thumbs up Re: KNOCK! weird one though....
X2, Just bought a really clean chevrolet caprice and the owner thought the oil pump was bad and making noise. I knew different plus he had told me the longer he drove the car the quieter it got so i knew it wasn't a bad oil pump or the motor would have locked up long ago. I trailered it home, put it on jack stands and voila.. loose torque converter bolts. Tightened them up and it purrs like a kitten now.
1969 RS/SS DROPTOP is offline
post #7 of 13 (permalink) Old Oct 5th, 11, 11:04 AM Thread Starter
robert
nope, not the torquebolts.
when i pull at my exhaust (near the engine) hard enough it disappears.
so i should think my header is touching the subframe, but it doesnt....?
I allready checked that like 5 times.
very weird...
Z28 1984
post #8 of 13 (permalink) Old Oct 5th, 11, 11:11 AM
ZaCamaro69's Avatar
If you have one, I presume you would have removed it when you checked the converter bolts, but do you have a plastic dust cover that might be making contact with the flywheel?
ZaCamaro69 is offline
post #9 of 13 (permalink) Old Oct 5th, 11, 02:17 PM
Steps
Without a stethoscope we can gess all day...the E brake cable rattling and with torque on the engine it takes up the slack....there are 100s of possiblites espec when thers is little indication fro location.
Steptoe is offline
post #10 of 13 (permalink) Old Oct 5th, 11, 05:17 PM
Jeremiah
I had one do the same thing and I had hell finding the problem. Turned out the mini starter gear didnt have enough clearance from the flex plate. The load of the engine when in gear does cause enough pressure on the flexplate that the clearance changes and the knock goes away. The reason it knocked instead of grind was because it had a slight warp.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #11 of 13 (permalink) Old Oct 5th, 11, 09:59 PM
Check the flexplate for cracks between the bolt holes. I'm talking about the bolts that go into the crankshaft.
I had a stock flexplate that had cracked between all of the bolt holes except for two. Made a knock that sounded like a rod knock as it allowed the flexplate to hit the starter nosecone. But only under certain circumstances like you have described.
You'll have to pull the transmission back a few inches to be able to see.
I'd suggest you buy the thicker flexplate before you take it apart and then just go ahead and install it.
Summit sells their brand and TCI sells one.
I'd bet they are made by the same Co.
1970 Camaro Rally Sport. All #'s match. Shadow Gray, black top and black Custom interior (RPO Z87). AM/FM and RPO Z/21. PS, PDB, AC. Owner since 1989.
1970Z/22 is offline
post #12 of 13 (permalink) Old Oct 6th, 11, 12:23 PM Thread Starter
robert
i checked the flexplate, the bolts are tight.
when i pull the exhaust a bit, it disappears , so im making a bracket for the exhaust that keeps the exhaust a bit more to the right.
its not THE solution, but hey, if it works, its fine with me.
I have to hurry with getting all the rust from the body before it gets too cold and wet outside.
I dont have a garage so i have to do everything outside on the street.
Z28 1984
post #13 of 13 (permalink) Old Oct 6th, 11, 02:15 PM
Steps
Hey I was just being a little flipant above about the exhaust above lol..
I have had a faint tap /ting for years at cruise that can be heard if the window down and pass a wall at a partular speed about 15 to 22 mph which is related to my above post.
Steptoe is offline
