hard cranking, when HOT - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 20th, 01, 01:59 PM Thread Starter
hey guys in the summer time, I had to install a new Intake gasket. And ever since then the car has been cranking over hard, only when it's hot. I got out in the morning and start it right up. But after it runs about 10 min or more i shut it off, and it'll barely start up. It'll sit there and just crank over hard like the battery is dead. it'll take about a minute of straight cranking then it'll fire up. sometimes when it does fire up it'll stall real quick, then i'll try agian and it'll turn right over. It's embarrasing going to get gas, you pump about 10 bucks in, then try to start it, just doesn't happen right away, you have 4 other poeple behind you waiting to get gas also. Any advice on this problem is greatly apreciated. Thanx
1984 Camaro is offline
post #2 of 11 (permalink) Old Jan 20th, 01, 04:30 PM
Have your timing checked. If this isn't it, it could be a heat soak problem with your starter. Good luck........KZ
John D. Smith
69' SS/396
www.geocities.com/kz1000ltd
kz1000ltd is offline
post #3 of 11 (permalink) Old Jan 20th, 01, 05:47 PM
mccorry's Avatar
I agree with KZ...sounds like the timing is too far advanced...
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 12/22/00)
mccorry is offline
post #4 of 11 (permalink) Old Jan 21st, 01, 05:07 AM
After you set the timing check all your ground straps to the engine.
arley is offline
post #5 of 11 (permalink) Old Jan 21st, 01, 08:48 AM Thread Starter
Witch way do i turn it so it's not so advanced? towards the firewall or away from the firewall. And if it's a heat soak problem, will the starter shield take care of it. Thanx
post #6 of 11 (permalink) Old Jan 21st, 01, 09:09 AM
mccorry's Avatar
Turn the distributor clockwise to retard the timing (this is looking down on it).....
mccorry is offline
post #7 of 11 (permalink) Old Jan 21st, 01, 10:51 AM Thread Starter
thanx alot, i turned it about an 8th or a turn maybe more, and it worked just fine, now it just don't pick up as fast as it use to, and it sounds alot different. Thanx
post #8 of 11 (permalink) Old Jan 22nd, 01, 01:31 AM
i had the same problem in my 79 had a 400 sb when it was hot it didnt want to start i let of the key then it sounded like it didnt have any compression. so i backed off timing just a little worked great but there every now and then it would do the same thing. but only about 25% of the time. took starter off and cleaned out about 2lbs of dust lubed bearings and got a starter shield for about 15 bucks never didit again. Sold the car 5 yrs ago but the man said it hasnt done it with him. i think it is a combo of 2 problems one more than the other. just putting my piece in
oneforu is offline
post #9 of 11 (permalink) Old Jan 22nd, 01, 06:34 PM Thread Starter
I was thinking of getting a starter shield also. I backed off the timming some, and now when I smash on the gas to take off it'll just spit, pop, and stutter. DO i have the timming to Retarded? I'm going to pick up a starter sheild this week sometime. Thanx for all the advice. need to know about if i have it to retarded though.
post #10 of 11 (permalink) Old Jan 23rd, 01, 09:15 AM
i had the same problem with my 69 camaro and the battery amps were to small had a 650 cranking amps. went to a 1,000 cranking amp batt. and never had any more problems. hope this helps. jimbird
jimbird is offline
post #11 of 11 (permalink) Old Jan 29th, 01, 05:56 PM
I would suggest not just guessing at the timing and setting it correctly with a timing light. Your car will run better and it will start like it is supposed to.
dellerbe is offline
