HEI hookup - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 7th, 03, 03:59 PM Thread Starter
How do i hook up HEI distributor i put a ten gauge wire to the fuse block it worked for a while but stoped whats wrong????
dill is offline
post #2 of 6 (permalink) Old Jun 7th, 03, 05:39 PM
If you still got 12 volts goin to the distributor, then the problem is inside the distributor. Probably the module
post #3 of 6 (permalink) Old Jun 7th, 03, 05:54 PM
joseph l clance
joe clance's Avatar
Check your connection, or fuse.
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #4 of 6 (permalink) Old Jun 9th, 03, 06:42 PM
Stopped while running or wouldn't start a second time? Your electrical source might be wrong where it's on a ignition on source that cuts out while cranking but you got lucky starting since the engine might of still been turning when letting off the key and the power returned to the distributor. Check voltage when cranking.
Snatchin'gears is offline
post #5 of 6 (permalink) Old Jun 9th, 03, 10:55 PM
make sure you don't have the positive to the negative and the negative to the positive.
the car will only run while cranking and then stop once cranking stops;
Vinny69 is offline
post #6 of 6 (permalink) Old Jun 10th, 03, 12:07 AM
Oh yah. There's a death to HEI's if some of the wires like the tach are hooked on wrong. Hope not.
Try reading help and trouble shooting on manufacturers pages like MSD or Mr Gasket.
