gas tank gunk - Team Camaro Tech
post #1 of 8 (permalink) Old May 1st, 01, 05:06 AM Thread Starter
My carb keeps fouling. Every few months I have to pull the top off and clean out the gunk that's accumulated in the bowl. I've obviously got stuff in the tank. Think it's worth a shot to drop the tank and blast water in there with a hose? Or is there a better way to clean it out?
convertibleRS is offline
post #2 of 8 (permalink) Old May 1st, 01, 05:19 AM
Guess
HwyStarJoe's Avatar
Red face
Definitely NOT water! But you have the right idea.
There are products made specifically for cleaning out fuel tanks. A lot of the folks here can give you names of great stuff to use.
But I wouldn't stop there.... I'd either remove the fuel lines and clean them out, or replace them also.
It sounds like the fuel pick-up in the tank is clogged or bad and is allowing crap to run through the lines. You may find that it needs replacement, if you can't get a new pickup screen/filter for it.
Good luck!
Joe
WCA Member
[email protected]
'69 wallet crusher
'97 Blazer - Bad wheel hop!
HwyStarJoe is offline
post #3 of 8 (permalink) Old May 1st, 01, 07:07 AM Thread Starter
Great. Thanks for the advice, Joe. Come to think of it, blasting water into a tank that already has a rust problem would be pretty stupid. Anybody know the names of any tank-cleaning products that Joe's referring to?
post #4 of 8 (permalink) Old May 1st, 01, 07:40 AM
mbrekke's Avatar
Por-15 makes a tank cleaning/sealing kit. Don't know anyone who has tried it though.
www.por-15.com
look under "auto fuel tank repair kit" in the products section.
[This message has been edited by mbrekke (edited 05-01-2001).]
mbrekke is offline
post #5 of 8 (permalink) Old May 2nd, 01, 02:10 AM
Rick
Definately drop the tank. For the cost, you may want to put a new one in. I did ( after clear coating it with POR15 Glisten PC - came out sweet ). An inline filter would help.You need to eliminate the source. The gas line should clear itself out when the stuff stops coming through.
RickD is offline
post #6 of 8 (permalink) Old May 2nd, 01, 11:22 AM Thread Starter
I thought about replacing the tank, but it looks like you need to weld the filler neck to the tank. Since I don't have a welder, that's not really an option. I like the idea of an inline filter, though.
post #7 of 8 (permalink) Old May 2nd, 01, 02:15 PM
Rick
If you have a 67/68, there's a rubber sleeve that connects the neck to the tank - commonly available. The 69's are complete.
Rick Dorion
69 RS Conv,355,M20,4:10
RickD is offline
post #8 of 8 (permalink) Old May 2nd, 01, 04:21 PM
Guess
HwyStarJoe's Avatar
After you drop the tank (always always have a fire extinguisher handy!) and empty it, take a look inside. It may not be as bad as you think. My rusty old original was spotless inside when I dropped it. Let it dry out for a few days and peek inside. I vacuumed mine out and checked all around the insides with a telescoping mirror. I was amazed! Maybe yours just needs to be cleaned out and a new filter put in-line somewhere.
Check out www.por15.com and look at their fuel tank kits. They have a repair kit ($49.95) that'll freshen it up if it's really bad.
Sorry! Didn't mean to duplicate Mbrekke!
Joe
WCA Member
[email protected]
'69 wallet crusher
[This message has been edited by HwyStarJoe (edited 05-02-2001).]
