84 camaro cruise control, windshield washer and wiper malfunction - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 26th, 00, 06:56 PM Thread Starter
Unhappy
My cruise and my washer do not work at all.My wipers work properly on low and high settings But in off position it acts like its on high delay and when I put it on delay the wipers just stop wherever there at on the wind shield at the time and do nothing until I switch to one of the other settings.HELP!!
Bob Phillips
Raven is offline
post #2 of 3 (permalink) Old Jun 28th, 00, 02:14 PM
Sounds like a ground wire problem, both units could share a common ground wire. look around for a wire that is disconnected around the fire wall area of the wiper motor
Rob.Canada is offline
post #3 of 3 (permalink) Old Jun 28th, 00, 02:17 PM
One other thing, did you pull the washer pump off the wiper motor? You have to use a pin to line the pump cam up with the the motor carnk, if you didn't then you will find that the pump cam is busted.
