Never underestimate spark plugs - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 23rd, 02, 05:00 PM Thread Starter
mwh
Marc
I've been trying to get my new 383 stroker running right for quite a while now. I am by no means an expert tuner, so it's been a real learning experience. The search feature here on camaros.net has been very handy and informative.
Since I first fired the motor, I've fixed a vaccuum leak, timing problem, re-adjusted the valves, and got the timing curve dialed in correctly. Idle mixture and accelerator pump cam are adjusted pretty well now. Don't get me wrong, all of this stuff has taken a lot of trial and error, and a lot of mistakes to finally get right.
So I come to my latest problem. Car was idling pretty good and would rev quickly, but as soon as I put it in 1st and let the clutch out, it would fall flat on it's face. Poor throttle response, and when I could finally get it moving, it would backfire out of the exhaust real bad.
The problem? The spark plugs!! Yep, they were sooty black from running too rich and from all of the other troubleshooting I had done. They were the plugs I first started the car with. On top of that #8 was even tightened all the way. It's real tight fit with the header, so even though I thought I got it tight, I must have been wrong. I am not sure how much it affected the motor, but it sure couldn't have helped. So the plugs were good enough to let the car idle and rev with no load, but that's about it.
Now that I have the new plugs in, it's like a completely different motor. The idle is smoother, it revs even better, and no more backfires when I let the clutch out. It's got a lot more power now, like I would expect from a 383. So don't underestimate what fouled, sooty plugs can do to your performance. It was like night and day for me. I can't wait to take it out for a real test drive tomorrow. It's never been farther than down to the end of my street! Sorry for the long note, just wanted to share my experiences with y'all.
-Marc
mwh is offline
post #2 of 5 (permalink) Old Aug 24th, 02, 03:31 AM
I once got a complete set of new plugs that were bad. Had just built the engine for a customer and was going to break in the cam for him. Around that time there was a lot of problems with condensors that were bad and what with the engine being new and having spark to the plugs and no access to a scope it took me a couple of days and a lot of cussing to figure out what was going on. Doh! You know to check the gap but then you just assume brand new plugs will be OK.
Georgia_Gearhead is offline
post #3 of 5 (permalink) Old Aug 24th, 02, 02:43 PM
Jerry
Send a message via MSN to blackvi
Hey guys!
Wanna Tell us what plugs you now run? I'm sure if you let us know the heads, and any mods you did to them, It will be helpfull!
blackvi is offline
post #4 of 5 (permalink) Old Aug 24th, 02, 03:55 PM Thread Starter
mwh
Marc
The plugs are plain old AC Delco R45TS. The heads are Dart Iron Eagles which were mildly ported.
Took the car for it's first trip out of the neighborhood today. Lots of power!
mwh is offline
post #5 of 5 (permalink) Old Aug 26th, 02, 12:03 PM
Jerry
AC delco R45TS is what I use.... nice!
blackvi is offline
