Heater core wiring help????? - Team Camaro Tech
post #1 of 8 (permalink) Old May 16th, 02, 02:49 AM Thread Starter
I am replacing my heater core in 68 camaro and on the top of the heater box on the inside of the car, there is the connection for the wires. It is actually a wire harness with a cardboard insert that gets bolted to the top of the box. Does this just sit down on the box and really doesn't connect to anything. When I unbolted the old one that did work before the heater core broke. It just pulled it right out of the box like it was not connected to anything. But the heater did work. This piece has a couple of spring on it. I hope I explained it right. Thanks, Erik
68 Camaro RS, Built 355, 274 Comp Cam, Sportsman II Heads 200 c.c. 2.02. Ported to Performer RPM Manifold and 1.75" Headers, 1.5 Roller Rockers, 650 Holley, Steel Crank, 4.11 Gears but no posi yet! TH350 tranny w/ shift kit.
Erik Beckett is offline
post #2 of 8 (permalink) Old May 16th, 02, 06:04 AM
The piece that you are referring to (cardboard piece with the spring and connector for a plug) is called rheostat. It controls the speed of your blower fan as you move the fan control lever. The blower will only work at one speed without it.
Rons68 is offline
post #3 of 8 (permalink) Old May 16th, 02, 06:10 AM Thread Starter
Does it actually connect to anything inside or does it just slip into the housing and get the two bolts in the top of it through the cardboard. Thanks, Erik
68 Camaro RS, Built 355, 274 Comp Cam, Sportsman II Heads 200 c.c. 2.02. Ported to Performer RPM Manifold and 1.75" Headers, 1.5 Roller Rockers, 650 Holley, Steel Crank, 12 Bolt posi with 4.11 Gears, TH350 tranny w/ shift kit.
post #4 of 8 (permalink) Old May 16th, 02, 06:23 AM
Mine didn't connect to anything inside, just two bolts holding it to the heater box. I'm definately not an expert on electrical things, but my guess is that coiled wire builds up heat as the current flows through it, so they mounted it in the heater box so that the air flow would cool it. I'm sure someone here knows if this is correct.
Rons68 is offline
post #5 of 8 (permalink) Old May 16th, 02, 06:24 AM
(double post)
[This message has been edited by Rons68 (edited 05-16-2002).]
Rons68 is offline
post #6 of 8 (permalink) Old May 16th, 02, 06:25 AM Thread Starter
Thanks, I am pretty sure that is how mine is too. Erik
post #7 of 8 (permalink) Old May 16th, 02, 09:16 AM
Guess
HwyStarJoe's Avatar
It doesn't connect to anything inside the box. You're right, it just mounts on the top so the coils are inside the air stream.
HwyStarJoe is offline
post #8 of 8 (permalink) Old May 16th, 02, 02:35 PM
JohnZ's Avatar
Yup, it's the heater blower resistor, and the coils get HOT on all speeds except "High", so it's mounted in the blower air stream. Doesn't connect to anything inside the heater box (if the coils did touch anything, you'd have a dead short and a fried harness).
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
