Carb question - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 24th, 02, 12:58 AM Thread Starter
Have a Holly 4brl with a 327 engine. Seems to me like it is running rich plus I am getting crappy mpg. How does one set the fuel/air mixture correctly? Do I need to take it to a shop with sofisticated equipment?
You guys are the best.
garymcl1 is offline
post #2 of 3 (permalink) Old Sep 24th, 02, 03:39 AM
You can go to holley.com for tech articles on how to set up the jets in the carb using a vacumn guage. I have a Holley 4150 600cfm on a 327 and get 15mpg. You may also want to check your power valve to be sure it is not blown.
68 convertible
ccpeat is offline
post #3 of 3 (permalink) Old Sep 24th, 02, 05:56 AM
I had the same problem with my 750CFM Holley. Changed the jets to #70 (comes with #72) but, the problem persisted. Found out that it was a bad vacuum leak at the intake. If the car is getting that much air, it will want to suck down more gas. Hope this helps.
1969, X-44, Export Model, Hugger Orange, Std. Int., BC Rear(soon to be a BT 12 bolt), PDB, GMPP 350HO, M22 Supercase, SSM Lift Bars, AirGap, Holley 750, FlowMaster American Thunder Exhaust, FlowTech Headers
Judd is offline
