Stalling issue - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 25th, 11, 06:28 AM Thread Starter
JDK
Stalling issue
Hello all,
First let me say that I am not a mechanic. However money tends to force us to be things that we would not normally be.
I have a 1991 RS with a v-6. The car had been sitting for about a year then I needed to start driving it again. It was running good over all but would act like it wanted to die at stop lights when warm. I changed the pluggs and added a little injector cleaner. On my way from work I noticed a point as I was accelorating when it cut out. I let off the gas and it ran OK. Got to the highway and hit the gas. About the time it hit third gear it died. Just like someone turned off the fuel. It would start and go 50 or so feet and die again like it was out of gas. Got it home and replaced the MAP sensor (the ony error it gave), reset the computer by disconnecting the battery and it ran better but still shut down when reaching hwy speeds. It did start and got me home as long as I didn't get going too fast. I removed the air filter (which was filthy) and ran it and it was better but still not right. Any ideas that I may be able to do?
JDK is offline
post #2 of 3 (permalink) Old Oct 25th, 11, 12:51 PM
Vintage 68's Avatar
Re: Stalling issue
Check and monitor the fuel pressure.
Should be @30~40PSI at idle and maintain that at speed.
If not, fuel filter is bad - fuel pump is failing - regulator is bad ...
Is this a manual or auto?
Stalling at stops can be a defective Converter Lock Solenoid valve ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Oct 25th, 11, 01:13 PM Thread Starter
JDK
Re: Stalling issue
Sorry, I should have mentioned that it was an automatic trans.
JDK is offline
