fuel pump hits cross member - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 9th, 02, 09:50 PM Thread Starter
I just got a chrome Eldebrock h/p mechanical fuel pump from Jegs.The problem is when I went to put it on it won't clear the crossmember on my 71 Nova.The stock one clears good.Also the Inlet port aims right towards the motor mount frame bracket,not that It really matters now.Have any of you had this problem with Camaros.If so where can I get a high performance pump that will fit?This might save a few of you guys a little grief.
69 Camaro SS 350 4 speed
71 Nova
gene stills is offline
post #2 of 3 (permalink) Old Aug 10th, 02, 03:42 AM
Is this one of those pumps that can be moved by taking out all the little allen bolts, twisting it in the right direction, and reassembling? I thought I've read about that on this forum before? Did you search the archives? Might be an easy fix......KZ
John D. Smith
69 SS/396 CLONE!
<A HREF="http://hobbystage.net/camaro/69ss396" TARGET=_blank>Hobbystage Texas Tornado Website
</A>
North Texas Camaro Club
kz1000ltd is offline
post #3 of 3 (permalink) Old Aug 11th, 02, 02:37 PM
Rick
I had that exact problem when I went to install a Carter pump. Turned out my car had mismatched engine/motor mounts. The short versions of each.With the correct setup, my motor was raised a good inch and everything fit fine. Sometimes interchangability works against us!
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
