rev problem on sbc 350 - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 31st, 11, 02:35 PM Thread Starter
Michael
Hello all, I'm new here and i need some help with this problem.
I have a sbc 350 that i built a year ago and whenever i rev the motor up (in park)to around 3000 rpm's or higher and try to keep it there, it will run smoothly for about 2 seconds and slowly descend to lower rpm's and sound very rough during the descend. I think it could be a carburetor problem or ignition problem. but could it be something internally like the valvetrane?
I had the rotating assembly balanced, running a large cam and mechanical fuel pump.
any help is appreciated!
HottRoder is offline
post #2 of 5 (permalink) Old Oct 31st, 11, 03:17 PM
Re: rev problem on sbc 350
Sounds like it's running out of fuel.
69 Pace Car and 69 Hard top
srode is offline
post #3 of 5 (permalink) Old Oct 31st, 11, 03:46 PM Thread Starter
Michael
I adjusted the carb to run a little more rich and played with the timing a bit but that didn't help.
also,it doesn't die it just descends to idle
post #4 of 5 (permalink) Old Oct 31st, 11, 05:39 PM
If it idles, could be the main circuit needing a good cleaning, ie, remove carb, tear apart and spray the bejesus out of it with carb aerosol cleaner and reassemble and adjust.
Could be float level is too low.
A good troubleshooting tip, while carb is open on the engine, spray some WD40 into the throat/air horn to see if engine rpm picks up. If it does, fuel delivery problem in carb.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
post #5 of 5 (permalink) Old Nov 3rd, 11, 10:12 AM Thread Starter
Michael
I just rebuilt the carb and i remember accidentally bending the floats, they may just need some proper adjusting.Thanks for mentioning the float level!
