Fuel Problem - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 5th, 01, 11:38 AM Thread Starter
Exclamation
I have an 89 rs 305 tbi. Lately it has been hard to start and the code 54 has came up twice (low voltage fuel pump). It only has 5 volts at the pump but 12 at the fuse. Is there something that regulates this voltage or should I be looking for a short?
Jack Hammer is offline
post #2 of 3 (permalink) Old Nov 5th, 01, 01:48 PM
Have you replaced the Filter lately, it is the best place to start. My old S-10 was getting lazy in the starting department, Finally got around to changing the filter, it was plugged solid, new filter, starts like a new truck.
Rob.Canada is offline
post #3 of 3 (permalink) Old Nov 5th, 01, 06:56 PM
make sure the ground wire at pump is clean and tight.Possible bad fuel pump relay.
sschevyfan is offline
