accumulation of oil on top of manifold.. - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 10th, 03, 02:45 PM Thread Starter
Send a message via AIM to TheAaronTheory
For some reason, I always have a little pool of oil on top of my manifold, right under the throttle area, under the driver side of the carb. Its only an ounce or two, but its always there. I soaked it up, and the next time i checked, it was there again. What could this be??
<a href="
target="_blank">68 Camaro</a>
TheAaronTheory is offline
post #2 of 8 (permalink) Old Mar 10th, 03, 02:49 PM
ZZ_430's Avatar
Oil going past the intake manifold bolts.
A good thread sealant would cure it.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 8 (permalink) Old Mar 10th, 03, 05:55 PM
Send a message via AIM to Spames
Whew. Good luck getting it to seal. I've fought the same problem before. I hear it's hereditary.
Spames is offline
post #4 of 8 (permalink) Old Mar 11th, 03, 01:06 PM
Call me Funk
Send a message via AIM to CFunK
I had the same problem. Pulled offending intake bolts and used a Permatex product with teflon. So far so good.
-Funk
CFunK is offline
post #5 of 8 (permalink) Old Mar 11th, 03, 01:52 PM
Bruno
Angry
Had that problem and little luck with the thread sealers I found around here, thanks God I ordered this wonder washers from Mc Master Carr,
http://www.mcmaster.com/param/asp/ps...21&desc=Bonded
Good luck [img]graemlins/thumbsup.gif[/img]
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #6 of 8 (permalink) Old Mar 11th, 03, 02:31 PM
I've used plumber's pipe dope with good success.
BPOS is offline
post #7 of 8 (permalink) Old Mar 11th, 03, 09:42 PM
Sean
i've used arp thread sealant, and it's yet to let me down. a buddy always uses rtv, and thats always worked for him. good luck [img]graemlins/thumbsup.gif[/img]
Sean
Franklin D. Roosevelt
68rs406 is offline
post #8 of 8 (permalink) Old Mar 12th, 03, 02:24 AM
Eric
I've never used anything but RTV and it has always worked for me. Don't overlook a leaky valve cover gasket though, if one leaks from the intake manifold side the oil can wind up on the intake.
Eric68 is offline
