95 camaro no power to fuel pump. any ideas? - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 9th, 11, 02:59 PM Thread Starter
steve
i changed the fuel pump, and the relay. checked for spark. fuel pump just dosent kick on. i need help
mud4594 is offline
post #2 of 3 (permalink) Old Nov 9th, 11, 03:51 PM
Vintage 68's Avatar
Re: 95 camaro no power to fuel pump. any ideas?
Have you checked for power to the pump?
The Gray wire to the pump should be hot for a couple seconds at key-on and then hot after start.
Check the supply fuse (#5 IGN/pump = 15amp).
Check for power at the Pink wire to the Fuel Pump relay.
If power is there try jumping the Pink and the Gray wire a listen for Pump - if it runs then issue is with relay power or ECM ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Nov 10th, 11, 07:44 PM
prostreet69camaro's Avatar
Does this motor have a distributor. My 91 truck with 350 had the same problem. I could pour gas in the throttle body and it would try to fire. But no fuel pressure.
The dist. gives pulses for the injectors to work. My module was bad. Changed the dist. and it ran fine.
prostreet69camaro is offline
