Exaust Backfire under deacceleration - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 16th, 01, 06:53 AM Thread Starter
Ok, What does it mean when you hit the gas, your 350 mild build small block with a holly 600 CFM Double Pumper runs ok, then when you release the pedal and coast your engin starts backfireing in your exaust.
I think it means my idle metering screws are set to rich. What do you guys think?
Blk69 is offline
post #2 of 8 (permalink) Old Oct 16th, 01, 07:05 AM
Cool
Yep!!
post #3 of 8 (permalink) Old Oct 16th, 01, 07:37 PM
Is it a real loud backfire or just a angry popping sound?
Could be backpressure
***My 92 305 is probably the weakest V8 in the world...just as long as I beat the Asians***
blbcamaro is offline
post #4 of 8 (permalink) Old Oct 17th, 01, 05:04 PM Thread Starter
it is usually a multi crackling sound.
Blk69 is offline
post #5 of 8 (permalink) Old Oct 19th, 01, 11:34 AM
Thumbs up
GUYS, I'VE BEEN LOOKING FOR THAT DECELERATION BACKFIRE SOUND FOR YEARS! SCARES THOSE IMPORT KIDS AT THE LITE WHEN YOUR COMING TO A STOP, I GUESS THE QUESTION IS IS THIS HARMFUL TO ANY THING, BECAUSE IF ITS NOT, YOU'L HERE ME COMING!
dale771 is offline
post #6 of 8 (permalink) Old Oct 19th, 01, 12:11 PM
i just went through 6 months of a popping noise. it was the pullution pump pumping air into the exhust on deceleration.
beattie z28 is offline
post #7 of 8 (permalink) Old Oct 19th, 01, 12:47 PM Thread Starter
I am worried that one day one of those pop's is going to be my valve shotting out my block
Blk69 is offline
post #8 of 8 (permalink) Old Oct 19th, 01, 10:19 PM
XK1
Beattie z28 is right, if you have a smog pump with bad 'check valves' it can backfire pretty loud sometimes on decel. Also check for an exhaust leak pulling in fresh air, keeping your exhaust burning in the pipes.
XK1 is offline
