Gas cap leaking - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 14th, 03, 06:25 PM Thread Starter
I replaced my filler neck recently but when I accelerate hard or take a turn fast, gas still leaks out from the cap. Will a "quality reproduction" fix this? Has anyone bought a RS cap from Ground Up?
Do most people keep the steel cable on the gas cap? How do you keep the steel cable from scratching (more like gouging) the paint?
thanks
'68 Camaro 350 HO <br />M-21 26x11 ET Street<br />12.9 @ 105.83<br />1.830 60 ft.<br /> <a href="
target="_blank">http://www.geocities.com/mwalte41990/index.htm</a>
michwalt15 is offline
post #2 of 8 (permalink) Old Apr 15th, 03, 03:41 PM
Angry
When I replaced my leaking gas cap with one from Rick's it stopped the leak.
ZZ-28 is offline
post #3 of 8 (permalink) Old Apr 15th, 03, 06:37 PM Thread Starter
Do you not have a problem with the cable touching the paint?
thanks
post #4 of 8 (permalink) Old Apr 16th, 03, 04:21 AM
I cut the cable that came with the cap that I ordered from Rick's. To me it had disaster written all over it as far as the paint is concerned.
4Barrel is offline
post #5 of 8 (permalink) Old Apr 16th, 03, 09:55 AM Thread Starter
That sounds like a good idea, thanks. [img]graemlins/beers.gif[/img]
post #6 of 8 (permalink) Old Apr 17th, 03, 05:40 AM
I haven't had a problem with the stock RS gas cap cable chipping the paint on mine. Do you have it indexed correctly?
68RSZEE is offline
post #7 of 8 (permalink) Old Apr 17th, 03, 06:54 AM
Send a message via AIM to 1FASTZ Send a message via Yahoo to 1FASTZ
I bought a GM replacement cap for my 69Z that is supposed to be vented yet each time I remove the cap, I hear a huge vacuum release as I twist off the cap. Is this how it should be? Sure doesn't seem right.
1FASTZ is offline
post #8 of 8 (permalink) Old Apr 18th, 03, 02:24 PM
My 69 makes the same vacuume sound. I believe it is because the orginal return fuel line is no longer used (orginal SS car). There is no where to release the pressure. I have a supo-dad vented cap also.
Thou shall not convet they neighbor's Camaro<P>69 SS350
Blk69 is offline
