HELP. . Damn TBI - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 22nd, 01, 03:26 PM Thread Starter
Angry
I have a stuck open injecter! when ever you turn the key on it sprays,even when its disconnect! Please help should I replace it?Or what!
Minime is offline
post #2 of 3 (permalink) Old Oct 23rd, 01, 05:36 AM
Are you sure the injector is spraying?I've seen one time where the o-ring that seals the injector to the throttle body went bad and the fuel sprayed out.If it is actually spraying then by all means replace it.
sschevyfan is offline
post #3 of 3 (permalink) Old Oct 23rd, 01, 06:12 PM Thread Starter
Thank you for your help! But its working fine now it had something stuck in it. I blew it out with a little bit of air. I think it may have been a little bit of a O-rig or something? (A little rock..?)It was black and very hard. I ran some cleaner though it and it seems to been ok. I drove it all day. stop and go. and on the freeway. I put about 100 miles on it. not a promble its seems to run a little better to with the cleaner ran thought it!Plus I changed the inline fuel filter. Hell I dont know! But thanks for all the help!!
Minime is offline
