Low oil pressure - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 6th, 01, 09:47 AM Thread Starter
I have a Chevy 350 in my boat. It has new heads, oil pump, all check values, and new pan. At idle it is fine. Under load oil pressure drops to 10-20 lbs. This was checked with a manual gage. What could be cuasing this?
mike e is offline
post #2 of 10 (permalink) Old Apr 6th, 01, 09:56 AM
Are you sure the pickup didn't come off?
383 Speed-O-Motive stroker kit with Speed Demon 750, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and Hughes 3000 stall.Powertrax NoSlip Locker
Tracy Focht is offline
post #3 of 10 (permalink) Old Apr 6th, 01, 10:02 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by Tracy Focht:
<HR></BLOCKQUOTE>the pick up is fine
mike e is offline
post #4 of 10 (permalink) Old Apr 6th, 01, 10:03 AM
Does it have one of those screwball giant boat pans? They can cause all kinds of problems under load because the oil runs away from the pickup.
oger is offline
post #5 of 10 (permalink) Old Apr 6th, 01, 10:13 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by oger:
<HR></BLOCKQUOTE>
It has a stock pan. Thanks for your thoughts.
mike e is offline
post #6 of 10 (permalink) Old Apr 6th, 01, 03:17 PM
Bill
Mike,
Why did you replace the oil pump ???? If you did it for low oil pressure you probably wasted your money as oil pumps very rarely are the cause. If the motor has more than a few hundred hours on it and has oil pressure problems, it probably has bearing problems. Marine applications are murder on a motor, especially if it is not maintained. It is like getting in your car with the trunk full and 4 passengers, finding a fairly steep hill to drive up at full throttle, and pretend the hill never ends ! That is how I explain it to customers. Have a mchine shop cut open the oil filter and look for bearing material.
If you have new heads, that tells me the old ones either rotted through, or the exhaust manifolds did...getting water in the motor. Either that or they cracked. You will probably have to end up pulling the motor and properly fixing the problem
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1973 Z-28 ..one family car...Brother bought it new in 73
BillK is offline
post #7 of 10 (permalink) Old Apr 7th, 01, 04:13 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by BillK:
Mike,
<HR></BLOCKQUOTE>This motor was new in 98, and has very low hours on it, I'd say 50 tops. A valve got stuck after the winter causing the head problems, there is no bearing problems present, the oil pump was replace because we thought it would fix the low pressure problem, your right, it was a waste of money because the problme is still there. The motor runs great, just low pressure under load. Do you think it could be a bad distributor, a used one was installed just before this problem started.
mike e is offline
post #8 of 10 (permalink) Old Apr 7th, 01, 07:43 AM
DjD
DjD's Avatar
Red face
mike e,
Please don't take this wrong. If you would have stated everything you knew was checked out already it would have saved 4 people from spending time giving you answers you didn't need.
DjD is offline
post #9 of 10 (permalink) Old Apr 7th, 01, 01:57 PM
Check the plastic connector between the oil pump and the distributor! Go to a brass one.
1st & 2nd GENGuy is offline
post #10 of 10 (permalink) Old Apr 8th, 01, 04:23 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by 1st & 2nd GENGuy:
Check the plastic connector between the oil pump and the distributor! Go to a brass one.<HR></BLOCKQUOTE>
Thanks, will do!
mike e is offline
