94 camaro (dead) - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 19th, 99, 12:59 PM Thread Starter
I have a 94 camaro that wont start. It tries to start but diesel's and then dies. I have checked for fuel pressure and spark. It has fuel pressure at the shrader valve and has a spark but I think it is erractic and may be the cause. I did check for spark staight from the coil and it is fine. I have also checked the timing and replaced the the timing chain. I think the distributor is out and I hope i am wrong but i think the distributor unit is one pice and must be replaced as a unit. Any ideas of what could be wrong would be appriciated.
chris26 is offline
post #2 of 2 (permalink) Old Sep 20th, 99, 04:38 AM
Get a can of 89 cent starting and spray some into the air intake while someone tries to start it. IF it starts and runs for a few seconds, you know it is a fuel problem. IF not, ignition. These cars are noted for poor ignition. Running through a water puddle can short them out. Dealer fix runs about 200 to 250 dollars. Might be worth the cost to get it right without spending a bunch on stuff that don't work. tom
tom3 is offline
