86 camaro with no compression - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 28th, 01, 11:35 AM Thread Starter
My 86 camaro has no compression. what would cause this? would it be the cam? also, would it be easier to fix my 6cyl or replace it with a 350 4bolt. any info would be greatly appreciated. Thanks.
Jeff Hartland
pimpin_camaro is offline
post #2 of 4 (permalink) Old Feb 28th, 01, 02:06 PM
Probably not the cam, I had a 79 Caprice that had 5 wiped lobes and it still had good compression on all cylinders. You most likely have burned valves or broken rings on those cylinders. Did you try squirting some oil in the cylinders to see if the compression comes up afterwards. Hope this helps.
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
There are no strangers here, only friends you haven't met.
chev64 is offline
post #3 of 4 (permalink) Old Feb 28th, 01, 03:41 PM Thread Starter
I was mistaken, it my dads car and its an 85 2.8L but you advice will help, thanks.
post #4 of 4 (permalink) Old Feb 28th, 01, 11:33 PM
Lightbulb
[If you have a valve stuck open in the head it will cause that ,if that is not what it is it could be something simple like :are the spark plugs tight in the head,the chamber has to be air tight to have commpression ,valves or commpression rings.
T/A GTA is offline
