tranny leaking...from where??? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 10th, 03, 02:52 PM Thread Starter
Send a message via AIM to TheAaronTheory
My transmission seems to be leaking, because whenever I go on drives of about 10 miles or more (when the exhaust pipes heat up), it starts smoking. the smoke is from transmission fluid leaking on the passenger side pipe (i know this for sure becuase the pipe is COVERED with baked on fluid). It doesnt look like the pan itself is leaking, but there is a vacuum tube that has a rubber hose on it that goes into the tranny that looks like it could be leaking. Could that be the problem? Its been this way since I put the tranny in a few months ago. Can that vacuum line leak? Is it even a vacuum line?
<a href="
target="_blank">68 Camaro</a>
TheAaronTheory is offline
post #2 of 4 (permalink) Old Mar 10th, 03, 03:08 PM
My first guess would be your dipstick tube. If you have a chrome aftermarket one, they are notorious for leaking. The factory tubes can leak if they are bent in the area of the "O" ring. Your cooler lines also attach at the pass side, so give them a good look as well. If you have a T-350, the kickdown cable attaches right next to the dipstick tube, and leaks can develop there. If you have a cork pan gasket....they are notorious leakers also. And the vacuum modulator, at the rear of the trans, pass side, can fail and leak. Good luck!
BPOS is offline
post #3 of 4 (permalink) Old Mar 10th, 03, 03:58 PM
I agree BPOS. My dipstick tube pukes oil. Tie a piece of white cloth around the tube and see if it turns red the next time you start it up.
-dnult
dnult is offline
post #4 of 4 (permalink) Old Mar 12th, 03, 09:46 AM
Kevin
You could also check your cooling lines. On a TH350 they are on the passenger side. Sometimes they can be a bear. Rhat
KRhat is offline
