Overheating again!!!!!!! - Team Camaro Tech
post #1 of 22 (permalink) Old May 12th, 01, 12:05 PM Thread Starter
91z28
Red face
Well my 1991 V8 Camaro is still overheating after some work with the fans. The fans work properly both are coming on when they should. The problem is that when I'm on the freeway the car overheates up to 240 degrees and if I let it it would go all the way to 260. When I'm on the streets the car cools down to 210. I don't know what to do, the fans are working like they should. So I'm thinking of putting a new radiator a bigger one than the one that I have right now(less than a year old)I got it from Auto Zone. Any suggestions. Thanks.
Ivan is offline
post #2 of 22 (permalink) Old May 12th, 01, 12:31 PM
Are your fans turnig the right way a pusher and puller? Also maybe your radiator hoses are collapsing
[This message has been edited by white 78 (edited 05-12-2001).]
white 78 is offline
post #3 of 22 (permalink) Old May 12th, 01, 03:03 PM
Dale
Is it full of water?Is the radiator internally restricted? Like "78" said,check to see if the fans are blowing towards the rear of the car.They can be wired wrong,and blow towards the front.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #4 of 22 (permalink) Old May 12th, 01, 04:23 PM
Do you still have the air dam under the car???The plastic thing that scrubs on every bump
6-71BlownCamaro is offline
post #5 of 22 (permalink) Old May 12th, 01, 05:00 PM
If it cools down at idle its not the fans it has an airflow through the radiator or a partially pluged radiator problem.
oger is offline
post #6 of 22 (permalink) Old May 12th, 01, 05:06 PM
was there a problem before the work on fans?,if not i would really check that out 260 degrees is way to hot never let it get that hot,if you had problem before fan work check to make sure the radiator is flowing ok,autozone is prob. not the best place to get a good reliable radiator,also i had a 70 nova that started overheating i found the impeller on waterpump was slipping at times causing it not to flow when i installed new pump it was worse than before come to find out my pepboys waterpump was defective impeller was made with fins going in wrong direction,just take it 1 step at a time and you will get it there should be no need for larger than stck radiator(it was fine when new)good luck!!!!
the mechanic is offline
post #7 of 22 (permalink) Old May 12th, 01, 05:10 PM
Wink
have the radiator professionaly cleaned,should be around $50.its worth it and should cure your problem.
sldhd is offline
post #8 of 22 (permalink) Old May 12th, 01, 07:45 PM Thread Starter
91z28
Thanks for all the replies, yes I still have the air dam, under the radiator. I just clean the radiator today but still overheating. The fans do work properly they take the air to the rear of the car. I don't know what else to do, the car has given me alot of problems lately. Anymore ideas?
Ivan is offline
post #9 of 22 (permalink) Old May 12th, 01, 08:35 PM
Dale
With the temps.you have been running,could be an engine condition.Does it boil over?If the engine was the problem I would think you would have a problem at idle too.Long shot here...is the timing set properly,is it getting the proper advance?What about the exhaust,could it be plugged/restricted?I notice you also have an emissions problem.
dale68z is offline
post #10 of 22 (permalink) Old May 13th, 01, 09:55 AM
Wink
what kind of condition is the exghaust in?may converter is plugged? change the water pump?i bought one of those high flow pumps and the damn engine would run hotter the faster i ran it(new motor).so i took an old one kicking around and i'll be damn the engine ran cool ALL the time after the swap!!!! if the water is moving too fast it doesn't have time to remove the heat from the engine.
sldhd is offline
post #11 of 22 (permalink) Old May 13th, 01, 01:58 PM
sldhd did you have a thermostat in the motor that should be enough restriction to keep it from overflowing the coolant.
oger is offline
post #12 of 22 (permalink) Old May 13th, 01, 02:55 PM
Wink
i sure did, i would never run a motor without one. the make of the pump was FLOW COOLER. the thermoustat was an acurate 180 degree one.the only thing i could think of was that it was causing some sort of cavatation in the block at higher rpms.still have the same thermoustat in the motor. i also had put in a BRAN NEW 4-core radiator,so i know it wasn't that either.
sldhd is offline
post #13 of 22 (permalink) Old May 13th, 01, 03:06 PM
I had the same problem when I put a four core in my camaro i have a 1992. The problem was the lower radiator hose . See at high rpm the hose was calapsing so I went to autozone and got one with a metalspring inside of the hose it wasnt for a camaro it was really close to the same shape so take your old one with you and make sure their is a metal spring inside of the hose.
Rusty is offline
post #14 of 22 (permalink) Old May 13th, 01, 06:22 PM
Smile
never thought about that,i love these boards!!!!!!!
sldhd is offline
post #15 of 22 (permalink) Old May 14th, 01, 01:57 PM Thread Starter
91z28
Guys the hoses are all right. The engine is doing a noise so it could be the water pump. About the thermo I have a 160 degress would a 180 be better?
Ivan is offline
