68 rs headlights?? - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 25th, 01, 03:53 PM Thread Starter
Noticed the vacum lines on my headlights are cracked and old. The headlight doors will not open or close without help and I noticed a hissing noise at the cracks in the lines. First can I just buy vacum line from my local parts dealer or do I need to order the complete kit from a camaro source?? How much vacum does it take to open and close the doors?? Any suggestions will be appreciated? Would it be best to just replace all the vacum lines invilved?
Todd Miller is offline
post #2 of 9 (permalink) Old Feb 25th, 01, 04:33 PM
If you have Power Point for your computer I can give you a diagragm I made showing exactly how to run the hoses so they work.
68 RS, Ash Gold,pwr windows,Hounds tooth
CA420 is offline
post #3 of 9 (permalink) Old Feb 26th, 01, 05:32 PM
Jeff
Can i get the PPT file so i can open it in Powerpooint. I'm not at the headlights but i can print and save until such time.
HawaiianCamaro is offline
post #4 of 9 (permalink) Old Feb 26th, 01, 06:07 PM
CA420 can you e-mail me the diagram at [email protected] ? Thanks, Chet
[This message has been edited by Chet69RS (edited 02-26-2001).]
Chet69RS is offline
post #5 of 9 (permalink) Old Feb 27th, 01, 02:29 PM
I sent you guys the diagram. Hope it helps.
Todd, if you replace one side at a time and get the correct size hose you can go to the parts store and buy plain black hose. You may get confused as to which hose is which as opposed to the color coded hose from the kit. Put some tape on the hoses to distinguish which are which and you can pull it off later. Once the reservoir builds vacuum it doesn't take a lot to operate but it does bleed off alternately as you open and close them through the vacuum switch under the hood. Also make sure you have a check valve between the reservoir and the main vacuum source so the vacuum will stay in the tank.
[This message has been edited by CA420 (edited 02-27-2001).]
CA420 is offline
post #6 of 9 (permalink) Old Feb 27th, 01, 04:56 PM Thread Starter
Thanks for the help!! I don't have power point but would some how like to have the diagram you are talking about. I have thought of the act that if i just take all the hoses off i may not be able to get them back correctly. is there some other way you can send me the diagram??
thanks, Todd Miller WV.
post #7 of 9 (permalink) Old Feb 28th, 01, 12:10 PM
Jeff
Cool
Thanks for the diagram, it will come in HANDY in the near future.
Jeff
post #8 of 9 (permalink) Old Feb 28th, 01, 02:29 PM
Todd, I sent it to you in power point form but I will make another that you should be able to use. I know what it is like to need something and people leave you high and dry. I will get it to you shortly, and good luck with your project.
CA420 is offline
post #9 of 9 (permalink) Old Feb 28th, 01, 04:49 PM
Sent you a bitmap. If you have Windows you should be able to open it.
CA420 is offline
