help! code 34,on my 1985,2.8 - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 3rd, 01, 09:46 PM Thread Starter
I can't get rid of code 34.I have checked for air leaks,replaced mass air flow sensor,relay,and brain.Could my idle be to low?any suggestions would help.No other codes are coming up at this time and the 34 is not intermittant.
russayers is offline
post #2 of 2 (permalink) Old Jun 6th, 01, 12:30 PM
It is possible that the connections to this sensor are intermittent. It is also possible that the sensor you obtained is defective. Please check the other posting regarding the 87 with similar symptoms. Ray
RABarrett is offline
