86 2.8 no spark - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 26th, 01, 09:40 AM Thread Starter
I just rebuilt the 2.8 v6 motor in my 86 Camaro and now have no spark. The engine will crank but no spark at coil. There is power comming from one of the wires from the distributor to coil. Not sure what to check next? It ran when dissasembled (bad crank bearings). I think something may not be plugged in or shorted during reassembly. Help?
Pete86 is offline
post #2 of 6 (permalink) Old Mar 27th, 01, 10:14 AM
Lance
Unfortunitely I also have one of these. I just went through the same problem. Turned out to be a bad ignition module (IM). I have been through three of them. You can have the IM tested for free at most major parts houses.
Are there any trouble codes stored in the Computer?
Spitfire44 is offline
post #3 of 6 (permalink) Old Mar 27th, 01, 11:19 AM Thread Starter
Thanks for responding, I checked the computer for trouble codes and got 1 flash, pause,2 flashes. My maunal doesn't list that code. Maybe it's in the factory manual. Anybody know?
Pete86 is offline
post #4 of 6 (permalink) Old Mar 27th, 01, 11:23 AM Thread Starter
Thanks for your reply. I checked the computer for troumle codes and got 1 flash, pause, 2 flashes. This code is not listed in my manual. Maybe it's in the factory manual. Anybody know?
Pete86 is offline
post #5 of 6 (permalink) Old Mar 28th, 01, 05:55 AM
Lance
The 12 code means it is operating normally. The usual is three code 12's followed by any trouble codes (Three at a time), then back to a code 12.
Try here: http://www.euronet.nl/users/fo_elmo/techno.htm
It is a fiero site, but the computer codes and diagnostic link are the same.
post #6 of 6 (permalink) Old Mar 28th, 01, 01:56 PM
Cool
Pete lemme be of some assistance to you if I can...I just had another 2.8 in my car and had the same problem right off the bat. What I found was that the coil was getting 6 volts instead of the 1/2 volt that it requires. That can blow the coil right off. Give that a check and see how many volts that coil is getting. Should fix the problem. Grab you an ignition module...
Mr Bowtie is offline
