Sail panel lights wont turn off - Team Camaro Tech
post #1 of 4 (permalink) Old May 13th, 01, 11:35 AM Thread Starter
Angry
The sail panel lights on my 67 SS won't turn off. The funny thing is that they worked fine before I installed my interior (carpet, seats, door panels, kick panels, etc..) What do you guys think it could be? Where should I start to look to fix this problem? Thank you.
shadow53 is offline
post #2 of 4 (permalink) Old May 13th, 01, 02:28 PM
Lightbulb
i dont know if you have checked or not but i would think a fuse is blown. i had the same problem in my k5 blazer. when the door was closed the lights under the dash were on and when the door was open the under dash lights were off but the dome light was on. checked all of the fuses and there was one blown.
nate
cnred84 is offline
post #3 of 4 (permalink) Old May 13th, 01, 05:15 PM
David Pozzi
davidpozzi's Avatar
You may have run a screw through the return wire from the lights, grounding it. They run through the door sills, I think the driver's side.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
post #4 of 4 (permalink) Old May 14th, 01, 06:24 AM Thread Starter
David thanks exactly what I did. I fixed the wire and now it works fine. Thank you for the help.
shadow53 is offline
