Resto Tach Not working? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 25th, 02, 07:33 AM Thread Starter
I recently rebuilt a 327 and put it in my 67 camaro that came standard without a tach. I also put an MSD pro-whatever distributer in at that time. I took the fuel gauge out of the dash and put in an OER tach from year one. The tach has never worked right. It seems to be reading right at the lower rpm's, but when I rev it the tach will go up a ways and then fall slightly while jerking around the whole time. Since I never had the tach in while I had a points style distributer, I dont know if the tach/distributer combo isn' compatible, or if the tach is trash, but was wondering if there was another possible answer. Thanks,
Dan
Dwalk47 is offline
post #2 of 4 (permalink) Old Aug 25th, 02, 06:28 PM
MSD makes tach/fuel injection adapters that should fix your problem.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 4 (permalink) Old Aug 26th, 02, 10:07 AM Thread Starter
I have talked extensively with MSD and they don't seem to have a solution... Also, I don't have EFI so I'm not sure how that would help me.
Dwalk47 is offline
post #4 of 4 (permalink) Old Aug 26th, 02, 06:31 PM
I was on MSD's website and typed in tach adapter on their search engine. It said if your tach is acting erratically you may need tach adapter #8910 or #8920 depending on your application and if GM try removing the tach filter first. Consult a tech rep for more details. I can't believe they wouldn't try to sell you something if there was a remote chance it would fix your problem.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
