Transmission mount-95 Camaro Z28 - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 13th, 01, 03:34 PM Thread Starter
I've gone through 3 transmission mount brackets. Is there an aftermarket product that will eliminate this problem?
95Camarodude is offline
post #2 of 4 (permalink) Old Nov 13th, 01, 06:50 PM
Joe
Which bracket are you talking about? Theres one that goes from the rear end to the tranny and then I beleave one on top and one below the mount its self.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #3 of 4 (permalink) Old Nov 14th, 01, 01:16 PM Thread Starter
The mount in question is located below the auto transmission housing. It is sort of V-shaped with a rubber insert a bolt through the bottom of this mount connects it to the housing.
post #4 of 4 (permalink) Old Nov 14th, 01, 08:07 PM
Joe
Theres solid mounts that you can buy but there not the best thing to use on a street car. You could try a polyurithane mount, they tend to be stronger. Do you have a manual or automatic tranny?
