68 camaro gages - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 18th, 03, 07:48 AM Thread Starter
Red face
I have a 68 327 auto with air and I,m having trouble with my gages when I took it apart all the bulbs were blown I replaced them and noticed that the plastic circut board had rust under it not much but enough to think that that might have been my problem, so I cleaned it and also the back of my gages, now lights still dont work and the fuel gage doesn't work anymore, my turn signals work but when one flashes the other goes dim, and when I put a test light on the back of the steel gages it lights up, please help the trial and error approch is to expensive to mess with.
ks2kwik is offline
post #2 of 2 (permalink) Old Mar 18th, 03, 11:31 AM
Sean
is the center screw in the gauge panel tight, and if it is, is the ground strap there (behind the screw hole, attached to the panel) this is where your gauge panel is grounded. and make sure it has a good contact to the metal part of the dash. if the ground strap is not making contact, it will do as you describe. but, the test light lighting when you touch the metal part of the gauges is strange. i'm assuming you mean you ground one side, and when you touch the metal on the gauges it lights. is it brite? sounds like the gauges aren't properly grounded, and possibly the printed circuit has gone to ground, or in other words is touching, the metal on the gauges. if it was grounded well, and there is voltage applied to the metal, it should pop a fuse. just keep checking for bad spots in contact with metal on the printed circuit, and make sure the dash panel is properly grounded. if all you have is a test light (an ohm/volt meter would be better) put one end of the light to a known hot, then try touching the back of the gauges (metal part). it should light up if grounded. but first look into why there is voltage on the back of the gauges. hope this ramble made some sense. good luck, be patient, you'll get it
Sean
Franklin D. Roosevelt
68rs406 is offline
