ignition problem. no spark -> what must i do? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 19th, 03, 10:40 AM Thread Starter
Marc
Unhappy
hi !
i have an ignition problem , the engine don't start anymore.
The starter do work but there is no spark
Please can you tell me HOW i can check the coil and then check the distributor?
I 'd like to run directly the coil from the battery, jumping all the wires.
All i did since last start is :
rebuilt my muncie, so i needed to remove the distributor cap, and i also installed a new oil pressure sending unit so i disconected some ignition wires. But i think i re connect them all in place.
PLease tell me what you think is the best to check and to do .
I really want to have my engine started. i discovered this late today and haven't check anything yet . I don't know how to do this either.
I hope you'll help me,
THank you !
Marc
Camaro 1968, propane 327ci, Big Brake, Hotchkis, T56
Marc is offline
post #2 of 5 (permalink) Old Apr 20th, 03, 11:38 AM
Eh yuck. Can you do a full photo spred of your wiring? Anyway I think the hei distributors are real picky for wiring up the tach if your engine is upgraded with one. Hopefully that wire didn't get wired wrong because it's a death blow of sorts for the distributor.
The coil check I believe is a resitance check. Not getting the books out the best I can tell you is get the chiltons or other manuals.
Worse yet the type and year of stuff you have isn't listed. Good luck.
Snatchin'gears is offline
post #3 of 5 (permalink) Old Apr 22nd, 03, 09:34 AM
start by making sure you have 12 volts to coil < HEI >, or at balast<points> and check to see you have voltage<about 6>on other side of balast. Balast are know for going up.
68 Camaro~LSx ~all motor
post #4 of 5 (permalink) Old Apr 23rd, 03, 07:53 PM
David Pozzi
davidpozzi's Avatar
Marc,
Do you have the High Energy Ignition type - large distributor, or stock points ignition?
We can't help without some basic information.
davidpozzi is offline
post #5 of 5 (permalink) Old Apr 25th, 03, 08:19 AM Thread Starter
Marc
oh sorry i am really sorry i didn't respond... I did respond on that topic at another place here on the forum ...
ANYWAY , the car start now, i checked the xires, and i found one (white) wasn't well connected.
That was it .
thanks for your help
Marc
Marc is offline
