68 door buzzer - Team Camaro Tech
post #1 of 17 (permalink) Old Feb 7th, 00, 07:51 PM Thread Starter
Description: 68 w/ stock auto and V8. Whenever I open the driver's door on my 68, a buzzing noise comes from what looks like the horn relay mounted on the engine side of the radiator support, just below the voltage regulator. It buzzes regardless if a key is in the ignition or not. The buzzing quits when I turn the ignition switch on or close the door. If I remove the power from the relay, the circuit must break because I don't get any juice to the coil. If I remove a different wire so the buzzing stops, I blow the fuse that covers my turn signals when the ignition is on. The only thing I have done to the wiring is to put a new ignition switch and key lock in, and connect the neutral safety switch wires from a previous stock shifter. PLEASE HELP!!
Shayne is offline
post #2 of 17 (permalink) Old Feb 8th, 00, 05:38 AM
Hey Shayne, It is great to own an old classic, just think if was a 90s model the #[email protected]%&^ thing wouldn't run.
the buzz you here is the key in ignition warning, one of the first anti theft devices, seems people who leave the keys in the ignition would loose thier cars. don't know why????
Any ways to fix your problem pull the box that is buzzing off the car, this is the horn relay, if you are careful you can pull the cover off, by bending / straightening the metal tabs, inside you will find some coils and points, my guess is that the one of the point sets is stuck together, pry them apart and gentle file the contacts.
If the contacts are completely burnt you will have to get a new relay.
Make sure you clean the conections as well , sometimes they will rust and cause the same type of problems.
Let us know what you find.
Rob.Canada is offline
post #3 of 17 (permalink) Old Feb 8th, 00, 01:43 PM
mccorry's Avatar
I would say since it IS buzzing all the time, your relay is fine. Check to see if the switch in the ignition is stuck. I am not sure what you would call it, but it is what tells the buzzer relay the key is still in the ignition...
Good luck....
mccorry is offline
post #4 of 17 (permalink) Old Feb 11th, 00, 08:47 PM
To the best of my knowledge, I didn't think 68 Camaros had key-in-ignition buzzers. I thought that this started in 69 when they put the locking steering columns with the ignition switch on the column.
jrt67ss350 is offline
post #5 of 17 (permalink) Old Feb 14th, 00, 10:43 AM
Yes the 68 do have key in buzzer,it sounds like a sick cow but it is there.
Again it is the horn relay that does the buzzing.
post #6 of 17 (permalink) Old Feb 19th, 00, 03:24 PM Thread Starter
Unhappy
Well, I replaced the horn relay and it is still buzzing, only a little louder now. That leaves the ignition switch, but I just replaced it about a month ago. Is there anybody out there who knows where to look in the ignition switch?
--Shayne
Shayne is offline
post #7 of 17 (permalink) Old Feb 19th, 00, 04:43 PM
Gene
Thanks for the info Rob. The buzzer in my 69 does sound like a sick cow (perfect description by the way), so I thought about replacing it. Good to know it came from the factory that way.
gheatly is offline
post #8 of 17 (permalink) Old Feb 22nd, 00, 04:41 PM
Hey Shane it has been quite a while since I had a switch apart, I would start by pulling the lock tumblers out, insert a stiff wire (paper clip) into the hole and turn the key backwards past the ACC postion, once the tumbler is out look for some thing that is out of place, I think there is a small plastic tab that has somthing to do with the buzzer, is it bent out of shape, has the buzzer stopped now that you pulled the tumblers out? Thats about all i can help you with, also you might want to check the connections on the back of the switch, sometimes you can miss a spade completly, when you plug it on.
post #9 of 17 (permalink) Old Feb 24th, 00, 08:14 AM
Cool
Shayne, you said that if you close the door the buzzing stops. Try removing the pin switch in the driver's door jam. It should have two wires connected to it. One for the key buzzer and one for the dome light. By process of elimination, disconnect the wire for the buzzer and your problem should go away.
z28_pilot is offline
post #10 of 17 (permalink) Old Aug 14th, 01, 01:59 AM
I have a new engine (front light) wiring harness, new horn relay, new ignition switch, new ignition tumbler---and my key alarm goes off without the key in the ignition also. For me it must be a problem in the dash wiring harness (it's a rat nest from different people adding/removing things). The wiring diagram isn't a huge help in this area, but it's a start.
djunod is offline
post #11 of 17 (permalink) Old Aug 14th, 01, 01:45 PM
When I got my 68 convertible there were no courtesy lights under the dash or in the back of the console. As soon as I put the first bulb in, the buzzing started. Key in the ignition or out, it would buzz with the doors open. My problem turned out to be a shorted wire on the back of my ignition switch, but a short term fix might be to remove the dome light and the console light.
Dave Richard
68RS/SS Convertible
L48 (350/295 Powerglide)
daverichard is offline
post #12 of 17 (permalink) Old Aug 15th, 01, 01:18 AM
Cool
My suggestion is to go to the library and look up in the books for the wire harness schematics and follow the wires. The removal of the orange wire at the horn relay will stop the buzzing caused by Key-in-Igntion, and as was suggested earlier, a theft-deterrent for the owner of the keys, to remove them before locking the doors.
Another good suggestion given by Rob.Canada is to look at the ignition switch. Plastic tab may be worn out.
Everett
post #13 of 17 (permalink) Old Aug 15th, 01, 02:46 PM
Exclamation
It's the ignition switch or the wiring to either the igintion or the relay. Do you have a connector that fits on to your igintion switch or is it like mine and just terminals??? If this is wired wrong it will buzz. Even though the wiring diagram for the 68 show a orange wire... I didn't have it. I actually have a pink with a black stripe which controls the buzzer in the horn relay. This pink with a black stripe wire goes to the center terminal on the igintion. I would trace that pink with a black stripe wire down and verify that it is in the center of the igintion and on the relay it should be on the #4 terminal.
Good luck.
Cars:
68 SS Camaro
73 Camaro -Daily Driver
Website:
http://68.dhs.org
ohayden is offline
post #14 of 17 (permalink) Old Aug 17th, 01, 01:37 AM
How do you tell which is #4 terminal?
Camaro - 1968 327 Coupe, 1986 Z-28 IROC Tuned-Port
Corvette - 1973 Mako Shark II replica, 1979 L-82, 1982 Cross-fire, 2001 Coupe
djunod is offline
post #15 of 17 (permalink) Old Aug 18th, 01, 05:21 AM
It should be written if it's OEM. If not then go to:
http://350ss.com/mycar.htm
and click on (comments) at top and then scroll down... there is a picute of a horn relay to match up to.
Good luck!
Cars:
68 SS Camaro
Website:
http://68.dhs.org
ohayden is offline
