missing at low rpm's - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 28th, 01, 07:37 PM Thread Starter
i have a 305 with tuned port injection and a 700r4 on it and some times when i hit the gas from a dead stop it dies a little then misses from about 500-1500 rpm's. i just put in new sparks plugs but could the be fouled all ready. i gaped them to .35 and then i thought i did it wround so i pulled them out and checked again so they are gaped right.
any one know whats going on?
Marky_24 is offline
post #2 of 6 (permalink) Old Apr 28th, 01, 08:32 PM
If your car is equipped with an electronic ignition, the gap should be .045 not .035.
68 RS red w/ white stripes
67 SS/RS restoring
camaroguy is offline
post #3 of 6 (permalink) Old Apr 28th, 01, 08:35 PM
I Must be falling a sleep at the wheel here but I assumed you have an HEI. Check your dwell if you have points, they could be worn out.
67 SS/RS restoring
post #4 of 6 (permalink) Old Apr 29th, 01, 10:06 AM Thread Starter
Talking
i do have hei and and it is computer controled but the sticker on the hood says .35 inch. do you think the parts guys could have gave me plugs that are to cold or to hot?
Marky_24 is offline
post #5 of 6 (permalink) Old Apr 29th, 01, 03:16 PM
What year are we working on? Granted the later electronics were .035 earlier .045.
Most I have used were AC 45 plugs which are a hot plug which the tune port needs.
67 SS/RS restoring
post #6 of 6 (permalink) Old Apr 29th, 01, 04:40 PM Thread Starter
its an 86.
well im not sure what the heat range is, it says autolite 24 on the package is that the heat range?
Marky_24 is offline
