green wire on alternator - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 21st, 99, 06:50 AM Thread Starter
The green wire on my alternator seems to be cut. Where does it go? My problem is that when I run the car it seems to be draing the battery because it won't start back up after running at idle. I' thing it's that green wire. Thanx
<BLOCKQUOTE>quote:</font><HR>
The night-time is the right time
****James Bondo****
<HR></BLOCKQUOTE>
Sureguy is offline
post #2 of 5 (permalink) Old Nov 1st, 99, 07:44 AM
I have a 68, the only green wire near the altenator, is the temp. sending wire. This wire is taped together with the altenator wires. There are three wires that connect to a Gen 1 altenator. It sounds like maybe the altenator belt is loose and causing your discharge problems
Rob.Canada is offline
post #3 of 5 (permalink) Old Nov 1st, 99, 07:44 AM
post #4 of 5 (permalink) Old Nov 1st, 99, 05:59 PM
The two wires that go to the alternator are dark blue and white. Plus the big red one to the output terminal. There should be a plug that goes in the back of the alternator. If it's gone, someone may have tried to put on a "one-wire" alternator.
Dave Birdwell is offline
post #5 of 5 (permalink) Old Nov 2nd, 99, 09:08 AM Thread Starter
That's why my battery drained! I plugged the green wire into the ground post on the alternator! Oh well thanx for the help.
****James Bondo****
<HR></BLOCKQUOTE>
Sureguy is offline
