more starting problems - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 20th, 01, 11:12 AM Thread Starter
Angry
first thank you to everyone who replied to my hei problem.now it'll run and shut off.but now the starter clicks as if the battery was dead but its a new battery,starter,neg batt cable,pos battery cable.im lost it will start if it sits but if you dont get it then forget it.itll just click and a loud clank like the starter hiting the fly wheel please help me i am lost.its a 67 camaro with a 350 out of 78 camaro. idont no what to do.thank you again
WOODY'S 67 is offline
post #2 of 4 (permalink) Old Jun 20th, 01, 12:15 PM
Buy yourself a remote starter switch. Connect the leads to the S and the other to the battery on the solenoid. If it does not click and turns over, you have a defective solenoid.
68 SS 396
camaroguy is offline
post #3 of 4 (permalink) Old Jun 22nd, 01, 05:59 AM
I had this problem with my camaro... Its your starter solenoid (the solenoid is in your starter)... It can't take the heat of the headers... Even if you replace your starter chances are this problem will happen again... The best thing to do is to get a starter relocation kit and mount it on your wheelwell... The second best thing is to wrap your headers with special header insulation... That should do the trick as well...
Good Luck
Joe Matheson
Black 67 Camaro
Black 67 is offline
post #4 of 4 (permalink) Old Jun 23rd, 01, 07:41 AM Thread Starter
Talking
THANK YOU TO EVERYONE WHO REPLIED CHECK THIS OUT.THE BATTERY WAS DEAD FROM PRIOR USE YOU CANT RUN A CAR WITH TWO VOLTAGE REGULATORS.OPPPPPPSSSSSS
