New Air Compressor Cycling Too Much - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 8th, 01, 03:28 AM Thread Starter
I just had a new air compressor installed in my 95 Z28 and it cycles on and off every 5 to 10 seconds. The click is VERY AUDIBLE and VERY ANNOYING. This cannot be a good sign. Help! Does anyone know about this? Also, the car hesitates when it happens.
Ul2M8Cyn is offline
post #2 of 4 (permalink) Old Mar 8th, 01, 04:31 AM
The freon is low...thats the only thing I know of that will cause that
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 4 (permalink) Old Mar 8th, 01, 07:35 AM Thread Starter
Thanks, Travis. It turns out that the freon is low - from the evaporator springing a leak. Now the dealer says they have to replace the evaporator because the new compressor made the old evaporator leak. I told them to replace the hoses too - Do you know of any other part of the system that could break down now? I appreciate your help.
Ul2M8Cyn is offline
post #4 of 4 (permalink) Old Mar 8th, 01, 12:48 PM
IMHO get the recever/dryer changed too. if the new comp. caused the evaporator to spring a leak i bet you had a little corision going on. they are ALm. but if the drain hole get's pluged they will corrode. or if water get's in the system too.
the resion i say get the reciver dryer changed is this is a sign of contamination in the system and the reciever/dryer will colect and hold the contamination. it is about a $50.00 part and if they change the hoses and stuff you will probabvly not get a labor increse hopefully. when i wrenched i would not have charged you more with all you are getting done.
ilbl8 is offline
