ECM codes - Team Camaro Tech
post #1 of 4 (permalink) Old May 27th, 01, 06:31 PM Thread Starter
I have a 83 z28 that keeps giving me code 42.I looked up the code and it says EST Electronic spark timming. It all began with the engine surging at idle. If u can help me please let me know.
thank you
quickstang is offline
post #2 of 4 (permalink) Old May 27th, 01, 06:51 PM
ZZ_430's Avatar
Well, without a scanner, i'd say replace the ignition module in the distributor. It's either that, the wiring to the module or the ECM itself. http://hometown.aol.com/zz430droptop67rs/
ZZ_430 is offline
post #3 of 4 (permalink) Old May 28th, 01, 03:19 PM
have you checked your timing, if it is not set properly or distributor is loose you will get surging at idle and a code 42. this is to let you know that the electronic spark control module is causing your timing to advance or retard too much. Put a timing light on it and check that.
trickster is offline
post #4 of 4 (permalink) Old May 30th, 01, 12:27 PM
Actually, the code 42 indicates that the ECM does not have control of the timing when it should. It is likely the module. Ray
RABarrett is offline
