350 turbo - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 20th, 00, 06:23 PM Thread Starter
i have a 69 camaro with a 468 pushing around 500+ hp. it has a 350 turbo trans. yesterday i got on it pretty hard and after 4 or 5 miles on down the road i notice it trying to slip a little. so i pulled off the road and checked the fluid . it was ok. then when i pulled out i pulled out in 2nd gear. no 1st, then i tried again, still no 1st. so i tried it manually shifting each gear and it worked perfect, but as long as i left it in drive i had no ist gear and it would shift from 2nd to drive pretty fast. what could be the problem? any help would be greatly appreicated. jimbird
jimbird is offline
post #2 of 2 (permalink) Old Apr 24th, 00, 09:52 AM
TH350? no first gear?> hmmmm, sounds like you either cracked ,squashed or burnt your Sprag Gear. usually they are near bulletproof on upshifts,
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
Chris Edwards is offline
