oil leak only after freeway driving - Team Camaro Tech
post #1 of 14 (permalink) Old May 12th, 02, 05:21 PM Thread Starter
i have replaced rearmain seal,valve covers,oil pan,and front seal. no leaks when sitting,or driving in town on side streets.10 minutes on freeway when i get home their is oil on the bottom of the munice 4 speed,and it looks like it was also on the bell housing.what would leak at high speed but not high rpm? around town. 70 mph 3.5 rpm on freeway. 4 to 5 rpm around town.stock 302 11to1 compression.
68 rs z28 is offline
post #2 of 14 (permalink) Old May 12th, 02, 05:42 PM
Check the rear intake manifold seal.
Could it be gear oil from the trans.?
Kyvox is offline
post #3 of 14 (permalink) Old May 12th, 02, 06:15 PM
if the trans is over filled, oil might come out of the vent in the tranny case, or the front seal might be shot.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #4 of 14 (permalink) Old May 13th, 02, 12:34 AM
Muncies always leaked. Mine leaked from the front countershaft bore in the front case. This hole butts against the bell housing, there is no seal for it.
But, if you wipe off the drip and smell it, does it smell like gear lube? Or thinner, like engine oil?
post #5 of 14 (permalink) Old May 14th, 02, 09:01 AM
I'd look at your PCV system...sounds like you have too much crank-case pressure at higher RPM.
Then I'd fix the oil leak created by the above.
If I were a gambling man, I'd put money on the above at even money.
Sleepy-69 is offline
post #6 of 14 (permalink) Old May 14th, 02, 05:02 PM
67 Camaros Rock
Joe Harrison's Avatar
Might want to look and make sure the bolt that plugs the fuel pump push rod hole is plugged 9 has a short bolt in it) if not it weep oil at high RPM and/or speed. You can remove the short bolt in this hole and install a longer one when installing your fuel pump. The longer bolt will hold the push rod up. You have to remove the long bolt and replace it with the short one so your fuel pump push rod will not be bound up. I have seen these bolts missing a number of times and when the hole is plugged the mystery leak disapears.
Joe
Joe Harrison is offline
post #7 of 14 (permalink) Old May 14th, 02, 05:34 PM
David Pozzi
davidpozzi's Avatar
My wife just bought a 73RS, the bolt was missing, the oil hit the starter and bellhousing area.
I see the crank keyway didn't get sealed either and is flinging very small amounts of oil from damper hub center.
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
post #8 of 14 (permalink) Old May 15th, 02, 11:38 AM
I agree with Kyvox that it is very possible that it is sneaking around the rear intake to block seal....if this is it and you decide to pull off the intake use a thick bead of silicone on the front and rear rails instead of the gaskets to seal it for good!
It might also be your mechanical oil pressure gauge line or fitting if it is connected back there too.
Also check your distributor gasket.
Good luck
Nate
eggersn is offline
post #9 of 14 (permalink) Old May 15th, 02, 05:31 PM
<BLOCKQUOTE>quote:</font><HR>Originally posted by eggersn:
I agree with Kyvox that it is very possible that it is sneaking around the rear intake to block seal....&lt;snip&gt; use a thick bead of silicone on the front and rear rails &lt;snip&gt;
Good luck
Nate
<HR></BLOCKQUOTE>
Make sure you force some into the crevace between the head and block, then make a proud 1/4" bead on the flat. Allow it to cure for a few minutes before installing the manifold.
-dnult
dnult is offline
post #10 of 14 (permalink) Old May 16th, 02, 04:07 AM
I've got two small blocks sitting in my garage and I can't find the bolt to which you are referring (the one near the fuel pump).
There is a threaded hole under the fuel pump, about a 1/2 inch in diameter, that faces down on the outside of the blocks. Is this what you are talking about? Neither are plugged with anything. Should they be?
Or, are you referring to the non-threaded hole in the fuel pump cavity of the block just under the pump rod hole (I don't believe this is to be plugged, but wanted to find out).
[This message has been edited by Sleepy-69 (edited 05-16-2002).]
post #11 of 14 (permalink) Old May 16th, 02, 06:00 AM
The hole under the pushrod hole is the drain back to the crankcase. Don't plug this one.
The threaded hole they are talking about is located on the front of the block, pass side, between the timing chain cover and the fuel pump, close to the oil pan rail. You will see two threaded holes vertical to each other. The top hole is the one to be plugged with a short 3/8-16 X 3/4 bolt and thread sealer.
You can also use this threaded hole to put in a longer bolt to clamp the fuel pump rod against its bore, to change out the mechanical fuel pump. Just be sure to remove bolt when done.
post #12 of 14 (permalink) Old May 16th, 02, 06:12 AM
Hmmm...didn't know that.
What is the hole under the fuel pump near the oil pan rail? It faces down...it's a threaded boss, about a 1/2 inch od?
post #13 of 14 (permalink) Old May 16th, 02, 10:09 AM
If it isn't any of the other above stuff mentioned and it is engine oil, then about the only source left would be the soft plug at the rear of the cam is oozing oil. If it is tranny oil, then maybe it is oil leaking past the oil slinger nut at the front bearing retaining flange on the muncie.
bonecrusher67conv is offline
post #14 of 14 (permalink) Old May 16th, 02, 02:28 PM
JohnZ's Avatar
The 1/2" hole in the pan rail below the fuel pump (which is not threaded) is a master machining locator - that's one of the points where pins on the precision conveyor pallet located the block during machining operations.
I see quite a few cars with the 3/8"x 3/4" bolt missing from the hole in the front that goes through to the fuel pump pushrod hole, and all of them show oil along the right side of the pan, motormount, starter, bellhousing, transmission, and crossmember.
Those two holes on both sides were there originally for the early passenger car front motormount brackets; the two on the right side weren't used again until the long water pump accessory drive A.I.R. pump bracket used them starting in '69. Without that combination, the through-hole should have a bolt (with thread sealer) in it, or you'll have an oil leak.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
