Battery drain - Team Camaro Tech
post #1 of 10 (permalink) Old May 1st, 01, 04:20 AM Thread Starter
Rick
I'm chasing a battery drain problem when the car sits - a 69 small block. When I measure the resistance across the disconnected battery terminals, I only get 6 ohms.Can some one tell me what a normal reading is?
RickD is offline
post #2 of 10 (permalink) Old May 1st, 01, 06:12 AM
Cool
Disconnect red wire at alternator. Six ohms is a light bulb or motor, heater blower, or wiper, washer pump,etc.
There should not be current draw with evrything off. Try hooking up battery at night time, see a light?
I just thought----glovebox light if equipped.
post #3 of 10 (permalink) Old May 1st, 01, 06:19 AM
DjD
DjD's Avatar
If you have a factory clock and/or a newer digital radio they are powered 24/7 and you will need to take them out of the loop before testing.
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #4 of 10 (permalink) Old May 1st, 01, 07:02 AM Thread Starter
Rick
No change after pulling fuses, disconnecting blower motor, etc. Is the voltage reg or horn relay supposed to be insulated from the radiator support?
RickD is offline
post #5 of 10 (permalink) Old May 1st, 01, 07:47 AM
Cool
Voltage regulator is mounred on rubber PALNUTS, but there is a ground strap from a bolt to the rad support.
Yes, clock and radio will drain also. Horn relay on firewall has a buss bar. One wire from battery to buss, the other wire goes into the firewall for rest of car.
Inside under dash drvr side, wire harness comes into cab, there is a crimp of two red (10 GA) wires One goes to firewall connection, one goes to light switch, and third goes to ignition switch from the crimp.
Dome light? Look behind the junction block by battery, (10 GA), I found rust between the back side of block and rad support.
post #6 of 10 (permalink) Old May 1st, 01, 01:32 PM Thread Starter
Rick
When I disconnected the red wire from the alternator, the resistance went to very high. I tested the alternator diodes/stator per the manual and it seems OK. But shouldn't I get a very high reading with the red wire hooked up? It seems like I have a grounding problem in the alternator windings.I'm frustrated.
RickD is offline
post #7 of 10 (permalink) Old May 1st, 01, 07:07 PM
Dale
I check battery drains by pulling the neg.cable and connecting a test light between the neg. cable and batt.terminal.Someone here sugested a buzzer,instead of a light.Watch the light,if it's dim,you have a short to ground.Keep disconnecting things or pulling fuses till the light goes out.Make sure the key is off and the dome light is off,(or close the door).
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #8 of 10 (permalink) Old May 3rd, 01, 05:19 PM
Lightbulb
Another way is to disconnect the neg and place a volt meter in series with the battery. neg to bat neg pos to neg lead to car. Now make sure key is off and doors are shut. The meter should read close to 0 volts. If it reads 12 dissconnect your alt and see how far it drops. It will go up if there is any type of drain. Start pulling fuses to isolate. I use a analog meter not a digital but it should work the same...
[This message has been edited by shadowjr (edited 05-03-2001).]
shadowjr is offline
post #9 of 10 (permalink) Old May 4th, 01, 07:01 AM
Smile
The only way to effectively check for battery (parasitic) drain is to use an ammeter. Disconnect the battery positive and hook the ammeter up in series between the positive battery cable and the positive battery terminal. Make sure all accessories are off, the doors are closed, and the key is off & out of the ignition. Most ammeters will only handle a 10amp load until they blow. The Fluke meters will handle 20amps I believed, but they are also fused. The cheap $70 meters from Radio Shack are porbably not fused.
You should observe less that .050 on your meter (50 miliamps) - this will not kill the battery for 2-3 months. If you have more than that, start by pulling fuses until the drain goes away. When it goes away, start inspecting circuits and components protected by the suspect drain.
glenn396 is offline
post #10 of 10 (permalink) Old May 4th, 01, 07:32 AM Thread Starter
Rick
Thanks to all. I know this isn't rocket science. I went the fuse route - no change. Since our beloved cars aren't totally fused, I started checked the alternator. I found the diodes are shot and am going to install a new one wire alternator.
Rick Dorion
69 RS Conv,355,M20,4:10
RickD is offline
