speedo cable replacement - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 31st, 02, 01:41 AM Thread Starter
Need to replace the speedo cable. What am I trying to feel for on the back of the gage? Does something need to be unscrewed or unsnapped or both.
Gary
garymcl1 is offline
post #2 of 3 (permalink) Old Aug 31st, 02, 03:11 AM
There is a small spring tab that holds the cable in place. Push up on that tab and pull the cable out.
kurt6325 is offline
post #3 of 3 (permalink) Old Aug 31st, 02, 10:22 AM
push the cable as tight into the back of the speedo as you can, then push the clip toward the speedo while pulling the cable off. kinda tricky up under the dash, but it can be done. an easier way to do it is to unhook it from the tranny, and pull it thru the firewall with the speedo then unhook it after everything is easy to get at.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
