Can't fill up without making a mess - Team Camaro Tech
post #1 of 18 (permalink) Old Sep 23rd, 02, 05:26 PM Thread Starter
When I go to fill up(with gasoline) I have to let it just barely trickle or gas will leak out from underneath the nozzle or it will just click off. Any Suggestions?
mike
michwalt15 is offline
post #2 of 18 (permalink) Old Sep 23rd, 02, 08:01 PM
Big daddy
hey mich,I have that same trouble,lets see if someone else does too,may it's common.
67ssclone 327 4spd 410
carhodge is offline
post #3 of 18 (permalink) Old Sep 24th, 02, 12:46 AM
There is no vent line between the tank and filler neck as in later years of autos.
You have to fill slooowww........let it gurgle.
post #4 of 18 (permalink) Old Sep 24th, 02, 02:56 AM
click's Avatar
Same here, slow filling as mollasses in January. I have to trickle it in at first click on the handle, pain in the buttkus.
In 1969 we didnt have to trickle it in, so I wonder what has changed? I used to fill up any car on full speed when I worked in a gas station in 1967, I got paid .65 cents per hour and during gas war we sold gas for .16 cents per gallon. Oh the good old days.
click
69RS 350/255 LM1, Balanced, TRW forged pistons, .30 over, TH-350 auto.,
Dover White,Blue Vinyl top, F&R spoilers,pdb, close ratio ps,am/fm,3.08 Posi., A/C, fold down rear seat
My RS www.brainerd.net/~knudsen/69RS
click is offline
post #5 of 18 (permalink) Old Sep 24th, 02, 03:49 AM
Call me Funk
Send a message via AIM to CFunK
How are you guys holding the handle? I find that holding it vertical to the ground I am able to run it almost wide open, around 3/4 of the way. If I hold it horizontal to the ground it spits and kick's off.
-Funk
My '67 RS
CFunK is offline
post #6 of 18 (permalink) Old Sep 24th, 02, 06:49 AM
click's Avatar
Funk? What part of the handle? Its hard enough to get the nozzle under the bumper and into the fuel opening with minimal space to lift the handle higher, but describe better what you are doing?
click
click is offline
post #7 of 18 (permalink) Old Sep 24th, 02, 09:50 AM
Yes please,
More info. Pic maybe?
1968 RS/SS 454 TH400 Black Deluxe Interior
"Another Day.... Another $100.00 worth of parts..."
Alberta 68RS/SS is offline
post #8 of 18 (permalink) Old Sep 24th, 02, 01:28 PM
Call me Funk
You '69 guys kill me. And you call it a 1st Gen.
Seriously, 67 and 68 shouldn't have a problem. I filled up tonight using the same procedure and ran it till it clicked off, then topped it off.
-Funk
My '67 RS
CFunK is offline
post #9 of 18 (permalink) Old Sep 24th, 02, 04:42 PM
click's Avatar
Oh sure bait and switch on me Funk
Try a 69 sometime under the bumper, its a pain.
click
click is offline
post #10 of 18 (permalink) Old Sep 25th, 02, 01:45 AM
Rick
On my 69, I hold the handle straight up/down and can fill just fine. The nozzle doesn't go far into the tank but I listen for the gas to be topping off the tank so I don't get any splash. The repro tank has the neck a little higher than stock, making it more difficult to get the nozzle end all the way in. I'm going to put some hard rubber blocks in to space it down.
Rick Dorion
69 RS Conv,355,Autogear M22,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #11 of 18 (permalink) Old Sep 25th, 02, 10:41 AM
I have never "filled" mine due to this "dripage" problem... '69's are worse case.Last time I put gas in mine<slowly> I watched as gas dripped from the rubber vacuum cap thing on the nozzle... not from the filler neck... go figure.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[email protected] W/ 2.73POSI.
post #12 of 18 (permalink) Old Sep 25th, 02, 10:54 AM
Call me Funk
It wasn't bait and switch, I assumed the first 3 years filled the same and Mike didn't specify what year in the original topic.
Rick's explaining what I was trying to convey.
-Funk
My '67 RS
[This message has been edited by CFunK (edited 09-25-2002).]
CFunK is offline
post #13 of 18 (permalink) Old Sep 25th, 02, 11:21 AM
click's Avatar
No problem Funk, just glad to know Im not the only one with this issue. Still I dont understand how they fill at full tilt back in the leaded gas days?
click
click is offline
post #14 of 18 (permalink) Old Sep 25th, 02, 02:39 PM
I find that if I do not shove the nozzle in all the way it will work better.
TTFN
Mat
Mat Klemp is offline
post #15 of 18 (permalink) Old Sep 26th, 02, 08:59 PM
On my 68, sometimes on hoses that have the "Vapor recovery system" the tank and filler neck will pressurize and shut off because there is no vent and I either hold the surrounding "collar" away from the neck to keep it from sealing, or just hold the hose at an angle so that it doesn't form a complete seal. This is the same technique I use for my street bike. Sitting on the bike, holding the collar up with one hand and filling the tank with the other.
Hoses without the vapor recovery system on it are usually full throttle fill ups.
Correct me if I'm wrong, but back when there were leaded and unleaded pumps, weren't the sizes of the nozzles different? The "Unleaded" nozzles had the springs around them and required a larger filler hole so you couldn't fill a leaded car with unleaded fuel...I believe that's the way it was. It's been a few years since I pumped "Leaded" and "Unleaded" gas into certain vehicles, I usually would just ask "Leaded or unleaded?"
Mike a.k.a. 68SS502
ZZ502, TH400 w/3,500 RPM stall and shift kit, 12-bolt posi w/4.11's. 3" Exhaust with X-pipe and 2 chamber Flowmasters.
[This message has been edited by 68SS454 (edited 09-27-2002).]
68SS502 is offline
